Is this for real?
Vehicle: 2000 Tiburon
BS!!!!! Its based off the fuel dump theory. Not worth it and will damage your
1.CAT
2.o2 sensors
3.environment
4.small cute furry ferrets
probably the same bs, as the resistor mod a few weeks ago.
"if its not used on the track, its crap"
i don't think hyundai and its oodles of engineers overlooked 15hp that could be harnessed without damaging your engine or causing problems.
just my 2c
[ April 08, 2002, 06:00 PM: Message edited by: Decker ]
1.CAT
2.o2 sensors
3.environment
just my 2c
No, this is a different scam... Certain cars (mostly older ones) would actually suck in some of the exhaust gas under certain conditions to keep emissions in check. This is called Exhaust Gas Recirculation, and the "flapper" that controls the exhaust gas coming back into the motor is called the EGR valve.
On cars that have an EGR system, that flapper closes when you floor the car so that your "request for more power" isn't obstructed by sucking in exhaust gas and reburning it. A bad EGR valve can cause hesitation and stumbling and can also cause poor performance.
However...
The Tiburons and Elantras with BETA engines do not have an EGR system. There is positively no place to put this flapper, because there is no EGR ANYTHING.
However...
The same guy is selling a "coolant line bypass" kit. Which, if I remember correctly, is just a matter of connecting both ends of the coolant line together, rather than running it around the TB.
Rip off!
Note to Random - I did search before posting, but didn't come across this thread smile.gif
Rip off!
Xorro, the theory behind that one is actually that the heated coolant will heat everything else (mainly the air going in through the TB). We all know that hot air = less dense = less hp. So the theory itself seems solid enough, but the amount of heating that the coolant actually does is probably so insignificant that you wouldn't see a difference.
http://www.stratusphere.org/cgi-bin/ib3/ik...t=ST;f=21;t=100
He also found the Stratus people.
We utilize EGR valves, and a company actually made the block off mod, till we proved it wrong.
It instantly threw codes to the ECU triggering the engine light. For the amount of work involved in getting it to work correctly, it would not be worth it, serously.
As far as the coolent line goes, well the Stratus radiator cap/thermostat/coolant line is all on the lefthand side of the IM. There is no line, except the straight 5 inch line that feeds into the coolent overflow resivoir.
Fools and their money are easily parted, but un-educated fools get scammed
BTW, a few of us reported this guy to Ebay.
If it seems too good to be true its probably Mothballs..
I just feel bad for the people who dont take time to check these things out and more people should report these things when they see them..
at best they do nothing at worst they hurt your engine either way your out some cash..
I wonder how many people have to use the warrenty for things like this or if they are even covered..
Loafy, I understand the principal and all that - I was just saying that if you didn't want to run the coolant around the TB, then you can do the mod yourself for about $2, rather than paying $10 to some guy.
