Coolant question.
Old Apr 14, 2002 | 07:53 AM
My2000tibby's Avatar
Vehicle: 2000 Tiburon
Default Coolant question.
I was looking at my car today and noticed that on top of the coolant reservoir there are 2 hoses coming off of it. One goes into the engine or wherever and the other is about 3 inched long and just hangs over the side of the reservoir. Then when I look down below the hose you can tell that coolant has ran down that side of the engine.
Is this normal. Aren't there are such things as coolant overflow, but I thought that it would go into another Reservoir not down the side of my engine.
Whats the deal?
Old Apr 14, 2002 | 08:14 AM
uz-2-b-phast's Avatar
It is the coolant over flow.. Some cars have an overflow reservoir some don't. it means you must manually check your coolant level. if you had and overflow as long as there was coolant in the res you would have enough.
Old Apr 14, 2002 | 10:47 AM
Why does it overflow?
Old Apr 14, 2002 | 12:40 PM
bad fingers should read
The coolant heats up. Pressure builds up. It needs a place to go. Does it do this often. Not really. But when it Does it is much better than your radiator exploding
Old Apr 14, 2002 | 01:16 PM
Veniston's Avatar
uz-2-b-phast:
Try using this:
It's the Edit button, allows you to change your posts, instead of filling up a thread with spam wink
