Air Fuel meter installation
Old Apr 18, 2002 | 07:40 AM
Nikos's Avatar
Vehicle: 2010 Sonata
Default Air Fuel meter installation
I' ve bought a Haltmeter and i want your help gus for the installation.First of all: It has 3 wires,1 red propably goes to power supply,1 red with black line goes to ground and 1 white goes to sensor L,at the begining of my exhaust.Till now am I correct??? Then... my sensor L has 3 different wires. How should i know which is the correct one that i should connect it with the white from the Haltmeter???? Should I use a voltometer? and how much should be the volts??? 0-1,1V????
Please guys help me.Has anyone used a same one?
Thanks Nick!!!
Old Apr 18, 2002 | 09:46 AM
Shadohh's Avatar
I am guessing hma webtech would have the answers you are looking for smile.gif
Old Apr 18, 2002 | 10:50 AM
Diambo's Avatar
The best equipment you can have for this install is a multimeter/voltmeter. The O2 sensor sends a signal voltage from 0-1.000V depending whether it's rich, lean or stoch. By probing this wires (one at a time) with the vehicle idling should give you the correct wire. The voltage should be continously changing within a certain range during idle according to your vehicle spec. Check the www.hmaservice.com for your vehicles specs. I installed mine from Autometer easily.
Old Apr 18, 2002 | 01:51 PM
just a warning...do not use the HMASERVICE wire colors as gospel. They are frequently wrong.
probe with the multi-meter and look for a varing signal between 0-1 volts. That's the wire you want.
