Question to people who have the XD cam installed
Old Apr 22, 2002 | 08:58 AM
Choopi's Avatar
Default Question to people who have the XD cam installed
As I am sure some of you know, I have been having problems with my friend's Tib ever since I put a cam in her.. I noticed today that the stock camshaft has a little "Tit" on the end of her.. Not the Driver's side, but the other side.. The XD camshaft I got from Hyundai DOES NOT have this "Tit"
I was thinking that it was a sending unit for the TDC Sensor (Hyundai's wording for a Camshaft Sensor) I got my car scaned today, and they said the TDC Sensor (Camshaft Sensor) was defective..
Not sure though.. All I know is my idle is rough, and I did not have that code before I put that cam in her car.. Just tell me if your camshaft had the Tit on it, please.. I will put a pic on here...
It is on the Right side of that pic..
Thanks in Advance guys..
~Matt
[ April 22, 2002, 07:53 PM: Message edited by: Choopi ]
Old Apr 22, 2002 | 02:27 PM
onpol's Avatar
The problem is your cam sensor can't read the signal without "the Tit" .There's got to be way to get the tit out of your stock cam and install it in your new cam.A machine shop can solve this problem.
Old Apr 22, 2002 | 06:49 PM
FluteMuffin's Avatar
Darn Tits, always messin with the guy's shafts! (cam shafts...you sicko's)
Seriously though! I hope you get that taken care of. I'm wondering if this is a defect in the cam you recieved? I have the new XD cams, but do not have them installed.
I actually have my cams sitting right here beside me, so I whipped the digicam out and snapped a pic of my shaft for you. Is this the tit?
So... if I have it on my XD cams, then something is not right with yours.
[ April 23, 2002, 02:05 AM: Message edited by: FluteMuffin ]
Old Apr 22, 2002 | 11:02 PM
Choopi's Avatar
Yup yup, that is the bastard.. I dunno why mine would not have it.. Hmm... I recon I will go to the dealer**** and get myself another camshaft..
Thanks guys.. :
~Matt
Old Apr 23, 2002 | 02:52 AM
Veniston's Avatar
Yeah a machine shop could get that out, or if you can get to the back side of it on your old cam (looks like the centre is hollow at that point), you may be able to move it out with some penetrating oil and a punch.
Unless the new cam didn't even come drilled for the peg, in which case it's defective smile.gif
Old Apr 23, 2002 | 02:47 PM
Veniston:
Yeah a machine shop could get that out, or if you can get to the back side of it on your old cam (looks like the centre is hollow at that point), you may be able to move it out with some penetrating oil and a punch. smile.gif
Only problem with that theory is that you have to have that "tit" perfectly aligned. If it is even 1 or 2 degrees off, the ECU will think the cams are in a different position, and will fire off the spark at the WRONG TIME. NOT GOOD.
Return the cam for a unit with the "tit" installed.
Old Apr 23, 2002 | 11:47 PM
Veniston's Avatar
Is that whole end unit threaded on? I figured it was a part of the main shaft, and the hole was drilled into that. It would be hard to screw up the alignment with a tight-fit peg in a close-tolerance hole. But if the whole end unit moves--I absolutely agree with you.
Needless to say I haven't actually played with the hyundai cams yet smile.gif
Old Apr 24, 2002 | 12:25 AM
Choopi's Avatar
Well, first off, I would like to thanks you guys.. smile.gif The "Tit" WILL NOT COME OUT.. I tried.. Even so, I do think there would be an alignment problem.. There is no reason for me to go through that much trouble if I can just go back to the dealer**** and say "HEY!! This one is defective" And they will get me another one..
Thanks Guys, I'll let you know what turns out of this!!
Old Apr 24, 2002 | 09:57 AM
Choopi's Avatar
Well guys, GOOD NEWS!!!
When I first got the cam, They said they had to order it from Jacksonville, FL.. about 3 hours north of me..
Got it the next day..
Today, I got there early enough for them to order it and have it here today.. smile.gif
Well, IT did not have the "tit" in it either.. I was like.. "DAMNIT"
I talked to the head Tech at the dealer****, Jimmy, and he said it was fairly common to not have them installed.. I asked what HE would do, and he showed me a machine.. (Now, I had MY stock cam in my car, since I had to drive it up there..) And I said "Well, how long would that take?" He said "Do you have the cam here?" I said "Yes" He said "Where" I said "In my motor"
He says "Pull your car around, we will do it right now."
And I pulled her around, and we pulled the stock cam, and he punched out the Tit.. He pressed the Tit into the new camshaft, and we went to put it back in and we snapped 4 damn bolts.. LOL
He got a new set of bolts, and we went back to work... Got it all done.. smile.gif
Now there is NO CEL, NO Hesitation, and NO problems.. And she feels GREAT!!!
I was skeptical about just popping the Tit out, and putting it back it, but Jimmy said it was alright.. smile.gif REALLY REALLY nice guy.. Bought him a 12 pack of Bud for it.. smile.gif He said if I ever had any problems to come back in and he would take care of me.
Happy Ending for a change...
Once again..
THANKS GUYS!!!!
Old Apr 24, 2002 | 12:34 PM
Decker's Avatar
way to go choopi!
