Exaust
Old Apr 12, 2002 | 08:05 AM
WooThis's Avatar
Default Exaust
Can someone please explain to me what the difference is between normal, and cat-back exaust systems. I also I am wondering if it is possible to make your own custom exaust if there is one that is not made for the type of vehicle that I have. I have a 2002 Daewoo Lanos, I cannot find an exaust anywhere for my car. Please help me out bro's.
Old Apr 12, 2002 | 11:46 AM
SilverTibby's Avatar
Whether normal or not, they are all "cat back." Cat back means that the exhaust is from catalytic converter to a muffler.
It is possible to make custom cat back for your car. Just go to a local muffler shop and ask them the price. It should cost around $80-120. The only major difference between your local shop custom exhaust and cat back exhaust from the company such as MHP, KORE, and Brullen is that custom exhaust is press bend, and aftermarket exhaust system is mandrel bend. Press bend will make exhaust diameter to change significantly when it needs to be bent (curvy section). On the other hand, mandrel bend are heat curved, so the diameter throughout the pipe are all same.
There is a trick where the muffler shop can replace only those press bent curve section with already pre-made mandrel bend pipe (such as 45 degree or U-band pipe). If done correctly, this could be as good as aftermarket mandrel bent exhaust system. You should expect to pay around $50 more for this "fake" mandrel bent pipe because they are a lot harder to make.
[ April 13, 2002, 02:36 PM: Message edited by: SilverTibby ]
Old Apr 13, 2002 | 05:50 AM
WooThis's Avatar
Thank you very much, I am goin out real soon to get a 2.5" exuast put on my 2002 Daewoo Lanos.
Old Apr 13, 2002 | 11:20 AM
WooThis:
2.5" is WAY TO BIG for your little 1.6L motor.
Go with a 2" and you should be fine. 2.25" tops, but 2.5" is WAY TO BIG.
Old Apr 15, 2002 | 07:14 AM
WooThis's Avatar
Can you explain why that would be to big, I am not arguing your knowledge, just for my personal knowledge I would like to know. Thank you.
Old Apr 15, 2002 | 07:29 AM
WooThis:
I can give you math formulas and all kind of other stuff, or I can just rest on my laurels and just state "personal experience". your choice.
Or you can read this.
