s-afc
would it be possible to set the afc to the settings that someone else on the forum has their set to.....i know that random suggested that i get my car dynoed, but would it work with someone else's adjustments????????????/
if your set up is the same as that persons car!
The only real way to do it is to get it on a dyno!
You have to take in account were you live and were the other person lives too!
Air temp,altitude and other things factor into this!
Do yourself a favor and spend the cash and get it dyno tuned!
No, even if your setup is the same as someone else, you cannot use their SAFC settings. Chances are there are that at the muffler or cat or exhaust piping is different...
Get it dyno tuned. it should only be about $150 bucks.
