CAI question
Old Oct 16, 2003 | 03:58 PM
bboynvus's Avatar
hey I just put on my CAI and noticed that it is a little harder to start anyone elese have this problem?
Old Oct 16, 2003 | 04:05 PM
javageek's Avatar
Did you reset your ECU? If not, disconnect the negative terminal off your battery, turn the key to the on position, depress the brake pedal for about 30 seconds, turn the key off, reconnect the negative terminal and start the car. Drive more agressive than normal for the first 50 miles or so. Should fix your problem.
Old Oct 16, 2003 | 05:34 PM
QUOTE (javageek)
that's a little hard for me to do... I'd end up wrecking if I tried that :?
Old Oct 16, 2003 | 05:44 PM
javageek's Avatar
Old Oct 16, 2003 | 08:12 PM
just get in and drive...
Old Oct 17, 2003 | 02:24 AM
It can take from 10 to 20 Driving cycles of 5 minutes or more to get your ECU fully mapped up to the new stuff.
Give it some time mang.
Old Oct 21, 2003 | 11:24 PM
NightShark's Avatar
yes.. just drive..
