More tranny help
Old Sep 24, 2003 | 05:15 AM
alz99's Avatar
Vehicle: FX Coupe
I have everything unbolted from he tranny,
But i can't seem to get it out still. It comes out about an inch and then it seems that something is sticking on the inside
Is it possible that it should be in a select gear or something
Help
also
Should this release leaver be removed fromt he tranny or can it still be attached.
It seems that this is my prob is it?
Old Oct 20, 2003 | 01:29 PM
hondakiller's Avatar
Yes, you need to remove the release lever from the shaft and the clutch slave cylinder off of the transaxle. Otherwise, the release bearing/release fork bind in the tranny and won't let you move it away from the engine. Also, your tranny should be in neutral. When I took out my tranny, mine also did not come out all of the way. It turns out the bracket for the tranny mount (closest to firewall) was hitting on the sway bar, so I had to disconnect the bar (not remove it). Just check all the way around the tranny. Also, if the tail of the transaxle is hitting on the drivers side frame "rail", you can angle the engine/tranny combo. downwards and take advantage of the space of the wheel well by slowly lowering the jack supporting the engine (you are supporting the engine, right?) and then the tranny jack supporting the transaxle. I hope this helps.
Old Oct 20, 2003 | 04:44 PM
alz99's Avatar
Vehicle: FX Coupe
thanks man
I solved it the day after posting.
but cheers anyway.
Old Oct 20, 2003 | 06:50 PM
Glad to hear you got it out without destroying anything (I hope) Front wheel drive trannys are a LOT more complicated to rip out than a rear wheel drive.
Old Oct 28, 2003 | 12:55 PM
alz99's Avatar
Vehicle: FX Coupe
Thanks mad
I destroyed nudda (thank goodness) but still have to replace the tierod ball joint boots.
It was such a pain in the rectum but in the end i learnt heaps and saved heaps $$(the probs with the brass button had me set back)
Old Oct 28, 2003 | 07:51 PM
First time I helped pull a FWD tranny was in a honda civic. We had the car on a lift and I was on one and end and the mechanic was on the other.. We got it all most all the way to the ground and the greasy bellhousing slipped out of my hands and it came down... and broke something off.. I forget what now.. He was not happy about replacing it either.
Glad you first experience was better than mine.
