whats the difference
Old Apr 3, 2003 | 01:16 PM
PrOjEcT BLuE 02's Avatar
Default whats the difference
between the safc and safc2
Old Apr 3, 2003 | 01:51 PM
Machine's Avatar
afc(version1), very basic, uses manual knobs to adjust fuel.
safc(version2), blue screen with buttons, much better.
Safc2(version3).
From the Japanese tuning giants A'PEXi comes the new S-AFC II super air flow converter. With new features such as increased levels of adjustment to 12 points at desired rpm levels. VFD display (vacuum fluroesant display). Knocking level indicator, 2 types of memory setting so it can be used for circuit and street. Password operation so that there is no tampering by others, warning light for air flow use, intake pressure, frequency of karman sensor, knocking and engine RPM.
Why get a safc when you can get a new better version. Basically does the same job, just not as well as the safc2.
[ April 03, 2003, 09:58 PM: Message edited by: Machine ]
Old Apr 3, 2003 | 02:56 PM
Same subject, has anyone installed BOTH of these in their tibbies? What's the difference in performance between the 2 when installed?
BTW, what's the price difference?
Old Apr 3, 2003 | 04:03 PM
it's rather hard to find an S-AFC, they haven't made them in quite a while. When people talk about an S-AFC, they MEAN the S-AFC II. If you check interior shots, everyone has the S-AFC II.
There should be no real HP loss/gain from using one or the other, execpt that the display on the II makes it a tad easier to tune, and should, in theory, give more consistent/better results.
Old Apr 4, 2003 | 12:28 AM
so whats the difference between the two pictured above.
Drew
Old Apr 4, 2003 | 12:30 AM
Skitzo's Avatar
The newest of them has twice as many tuning points in the rpm range....i think 12 now instead of just 6....and it also has connections to detect knocking.
[ April 04, 2003, 08:32 AM: Message edited by: Skitzo ]
Old Apr 4, 2003 | 01:00 AM
which is the newer of the one?
Drew
Old Apr 4, 2003 | 01:06 AM
techcontib's Avatar
S-AFC(version 3) is the newiest. I like the idea of having memory settings. The only problem I heard of right now is there is no english version of instructions. But I am sure it is probably not that hard to figure out. Zuppy at new tiburon has it install on his gtv6. But I don't think he has had it tuned yet.
[ April 04, 2003, 09:09 AM: Message edited by: techcontib ]
Old Apr 4, 2003 | 02:47 AM
Agarwal's Avatar
I have a S-AFC2 (or version 3) sitting on my desk; I should install it in my Tiburon 2000 in about a month. I'll certainly take pics and instructions if they're still not avalaible once I'm done.
Old Apr 4, 2003 | 06:33 AM
ok so should i get the one in the 1st pic or secon pic......whats the difference in those....
