STOCK Eclipse fuel pump
Old Aug 2, 2002 | 01:58 AM
JonGTR's Avatar
Default STOCK Eclipse fuel pump
I bought a Walbro fuel pump but got another pump thrown in with it free. It looks like a STOCK pump that matches the Walbro upgrade. How much more fuel would the stock eclipse pump flow over the stock Tib pump? Could this still be used for a mild turbo setup?
Old Aug 2, 2002 | 02:47 AM
Diambo's Avatar
If I'm not wrong it would flow 30% more. I would just stick with the Walbro in case you up your HP level in the future. Then, you won't have to mess with the fuel pump again.
Old Aug 2, 2002 | 03:19 AM
JonGTR's Avatar
I'm checking to see if I could give it to someone else for a small turbo upgrade.
Old Aug 2, 2002 | 03:53 AM
Diambo's Avatar
It would definitely work.
Old Aug 4, 2002 | 04:22 AM
Diambo's Avatar
SCCA 01 Elantra:
Would this also allow me to run an extra say 30HP to the crank for a max of 270 at the crank. Like he said wehats the crank HP limit of the stock eclipse fuel pump?
Maybe someone else can better explain this but I don't think it will be safe running the eclipse pump at that HP. You may get away with it but that will be pushing it. I don't know what the crank limit is either.
This graph may help you compare the flow rate of that pump v/s aftermarket pumps.
http://www.vfaq.com/FAQlocator-index.html
[ August 04, 2002, 11:24 AM: Message edited by: Diambo ]
