Will this cause problems / danger with intake???
Old Sep 5, 2002 | 10:17 AM
Tib's Avatar
Tib
Default Will this cause problems / danger with intake???
I just got my injen CAI put on, and removed the plastic gaurd (I guess is a good word)
from under the intake and was wondering if that will help seeing as though the intake doesn't sit that far down anyway
Is this a good idea yes or no???
Old Sep 5, 2002 | 10:27 AM
tibboy316's Avatar
u mean the plastic gaurd on the end of te filter...
i dont suppose if would hurt...but my theory is if its there its there for a good reason and unless u put a better thing in its place do like ur mommy told u and put it back were u got it
Old Sep 5, 2002 | 10:30 AM
Tib's Avatar
Tib
no not that plastic gaurd the one one the actual car, it looks like and air dam that pushes air down to the surface of the road
Old Sep 5, 2002 | 10:54 AM
tibboy316's Avatar
im not sure what u are talking about...maybe post a pic...or something if ur talking about the ram air type thing hyundai tried to creat you can take that off no prob while ur at it the the rest of the reantor off...umm if u mean that plastic gaurd on the under side of the car that shouldnt hurt anything but i dunno hwat ur talkin about
Old Sep 5, 2002 | 11:06 AM
EL Tiburon's Avatar
Dude, if it's anything that has to do with you air box assembly you can take all that stuff out.
Tib's Avatar
Tib
Yeah I'm talking about the plastic gaurd on the under the car. The only thing that I can thing of that would pose a problem, is water, since the injen intake doesn't require a bypass valve.
Old Sep 5, 2002 | 11:13 AM
tibboy316's Avatar
yea dude i dont see what that shoudl cause a problom...i do bleive the engine intake sits up far enough in the engine bay anyways so it shouldnt suck up any water... they make covers for them i think that you can put aroudn them???
Old Sep 5, 2002 | 10:22 PM
Tibb_Junky's Avatar
i think the piece you're talking about is a splash guard that's attached to the fender..... personally i wouldn't remove, but i guess everything comes down to personal preference. if you do remove it just watch out for deep puddles....hope i helped.
Old Sep 5, 2002 | 11:02 PM
JonGTR's Avatar
Yeah, it's just a splash gaurd. If you get a lot of rain, then I wouldn't recommend removing it. It blocks a lot of water from getting to the top of your engine bay, especially around your spark plugs. I've known several people including myself that had water get into their plugs.
Old Sep 5, 2002 | 11:10 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
If I'm reading this correctly, yeah, it's your splashguard. If you wanna remove it, be prepared for the alternator to short and debris carried by water to get into the belts and acclerate their wear and tear Not a good idea to take these off of your daily driver; for track-oriented cars these are usually replaced by a diffuser and/or an extended splitter which does the same job and adds downforce. There are ppl who actually pay good $$$ to have these replaced when they are damaged, which is pretty sensible because an alternator and a belt job costs a whole lot more than this part does. Also, dont underestimate how far water can splash, even with your intake mounted way up high, it can and will still become waterlogged, especially at high speeds in wet weather; when the cold water meets the hot exhaust manifold, especially without a vented bonnet scooping air out of the bay, well, you can guess what will happen.
[ September 06, 2002, 06:12 AM: Message edited by: MechaniX_034 ]
