raising comp ratio?
Old Sep 5, 2002 | 04:22 AM
Electrichead's Avatar
Default raising comp ratio?
my car comes factory w/ 9.5:1 CR. can anyone tell me how much hp i will gain ,and if my car can handle 11:1 or higher CR? or will something else splode?
Old Sep 5, 2002 | 04:27 AM
JAWS 021's Avatar
raising compression = more power but your more likely to ping
lower compressio = less power, but safer with turbo type setup
IF you are sticking NA... raise the compression
Old Sep 5, 2002 | 04:29 AM
Red's Avatar
Red
What car/engine are you dealing with?
Old Sep 5, 2002 | 04:55 AM
a 2k2 kia spectra 1.8l I4 ..im unsure if its a hyundai engine or kia's own but most likely a kia engine i dont think hyundai put there engines in kias at that time..and what would i do to keep from pinging? higher octane or timing adjustment? most likely im staying NA
[ September 05, 2002, 11:58 AM: Message edited by: Electrichead ]
Old Sep 5, 2002 | 05:08 AM
Red's Avatar
Red
Higher compression will do very little until you address other points in the engine:
Cylinder head ports
Cylinder head combustion chamber
Valve sizes
Cam shaft profile
Intake manifold
Exhaust manifold
Until you've attacked these first, raising your compression will not do a lot. This goes for any motor, V8's follow the same process as we do.
Old Sep 5, 2002 | 05:55 AM
ok so my process should go
BIM & BBTB
Headers/Full exhaust
Cams
Port/Polish
Pistons
what would be a good CR 11:1 11.5:1 higher/lower?
Old Sep 5, 2002 | 06:38 AM
MaierApril's Avatar
can these Kia's even handle the higher compression?
Old Sep 5, 2002 | 07:43 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Uhhhh dude just remember that the higher compression you run the higher RON Fuel you're gonna have to use. Go too high and you're gonna be shelling out the $$$$ for specific race fuels, and that stuff dont come cheap, or very easily.
Old Sep 5, 2002 | 10:02 PM
i figure maybe goin 11:1 because accents and tibs are already at 10:1 i think the kia can handle an extra 1.5 and i dont think id have to go to high with fuel either just raise the octane? to 97 with some octane boost?
Old Sep 5, 2002 | 11:02 PM
What fuels are conveniently avalible in your area???
