Headers
If you read the statement under the pic it says that they are.
-Dyno Tested and Proven
-Direct bolt-on without modification
-T-304 Stainless Steel mandrel bend for ultra fast flow.
-CNC Machine flanges with TIG and MIG welded construction
-02 Sensor position
-Hardware included
-Lifetime warranty from manufacturer defects.
I will be ordering an OBX header in a couple of weeks.
If your wondering, you can ask BV1 about his OBX header.
-02 Sensor position
-Hardware included
I got the proto-types. There were problems with it.
One was that I had to completely cut off that bottom part of the header because it was touching the oil pan, it wasn't long enough.
Two, It didn't come with flex pipe, I had to get my own.
Three, when putting the header, on the head, the nuts, that go on the studs, actually touched the welds on the header. They would not thread all the way up to the head, without touching the welds... wtf. Me and Alex (Jaws01) finally got them on, but they took alot of playing around with.
Now, it seems they have corrected all those problems, so thats not bad. But if your interested, theres some on ebay right now for 232... And if you contact www.ssautochome.com directly, they will give you a deal on the 4-1's, which come with flex pipe.
I wish I had waited for those ones, they look sweet...
-Steve
-Steve
