New lantra cam and vacuum
Old Mar 6, 2002 | 02:07 PM
Default New lantra cam and vacuum
The new cam (according to Red's recent post) dropped his vacuum 3-4 inches. Was that enough to noticeably affect the functioning of the brakes?
Old Mar 6, 2002 | 07:10 PM
Just a note here for turbo folks while we are on the subject of vacuum. I have a braking problem with my tibby.
While accelerating under full boost, if someone cuts me off, and I am forced to get on the brakes quickly after a full boost acceleration, the brakes are significantly weaker. With boost vs vacuum in the system, the brakes are MUCH weaker. The other problem is that the brakes then get stronger after the turbo spools down and vacuum builds. If you don't lift your foot up off the brake pedal slightly, you will end up slowing down MUCH faster than you had intended. There appears to be a 2-3 second delay involved.
to fix the problem, I plan on installing a "vacuum chamber" with a 1 way valve on it to "store" vaccum. Hopefully this will solve the problem.
Old Mar 6, 2002 | 09:29 PM
Jon's Avatar
Jon
Nice idea i hadnt thought about that.When you do it let us know how it goes as i might do a bit of a copy cat as its hard trying to find any parts here in germany.
