removing one cat
Old Mar 5, 2002 | 11:28 PM
arn's Avatar
arn
Default removing one cat
I would like to buy a 4-1 header. Instead of relocating the cat in front, can I just remove it.
will it still pass emission? and what will happen to the car when it is remove? whats the pro and cons? Random, Red, anyones thought on this please
Old Mar 6, 2002 | 12:33 AM
Red's Avatar
Red
There *IS* only one cat, regardless of what some people believe. The only cat on the car is the one right there in the engine bay. You rip it out for a 4-1 header, and it will fail.
Gotta put it back into the exhaust somewhere...
-Red-
Old Mar 6, 2002 | 03:05 AM
hyway's Avatar
Yep you need to have the cat also make sure your 02senser is behind the cat to keep your ecu happy.
Old Mar 6, 2002 | 03:16 AM
2K3GT/2K Wagon's Avatar
Red, There are 2 cats on my 2K Elantra, one one the manifold & one bolted to the mid-pipe. I live in Northern VA (outside Wash, DC) and my window sticker said California Emissions $100. I've had this verified by my dealer. I don't know what they have in your neck of the woods but I do have 2 cats and I'm sure there's others out there that do too.
Old Mar 6, 2002 | 03:22 AM
DESIGN's Avatar
double cats on mine.
Old Mar 6, 2002 | 03:47 AM
FordFasteRR's Avatar
double cats on mine too.
Old Mar 6, 2002 | 08:43 AM
Red's Avatar
Red
NO,sorry...
One catalyst, care to see?
1998-2000 models:
http://www.hmaservice.com/webtech/iindex.a...id=12630#_12630
All 2001+ models:
http://www.hmaservice.com/webtech/iindex.a...0597#_394880597
ONE CATALYST, and it's in the very front of your engine. You can check my work here: http://www.hmaservice.com/webtech
Key in your Tiburon year and engine type and select Emissions Control from the list.
Thank you, drive through.
-Red-
Old Mar 6, 2002 | 02:07 PM
SouthernShark's Avatar
Uhhhhh Sorry but their are 2 count them TWO Catalytic Converters on the tiburon. the one next to the manifold and one in the middle of the exhaust system. look here and learn something red.
1. choose what year tiburon you have
2. select Engine Mechanical System
3. select Intake & Exhaust System
4. Select muffler
5. Select Componets
6. scrool dow and read, or in your case look at the prety little pictures.
Old Mar 6, 2002 | 02:39 PM
arn's Avatar
arn
back to the topic at hand. there are two cats. one is right at the engine bay under the manifold after the o2 sensor and one after the flexpipe next to the 2nd o2 sensor. Now, when installing the headers, what do you do with the first cat? where do you relocate it? since it doesn't bolt on the header manifold. thanks for the help if you can clarify this,pls. Also, can someone sketch out a diagram on how to intall the cat(s) with the headers. For those pple that had the headers installed. thanks again.
[ March 06, 2002, 09:41 PM: Message edited by: arn ]
