carb aproved
Old Mar 22, 2002 | 01:44 PM
rx bandit's Avatar
Vehicle: 2000 Tiburon
Default carb aproved
just wondering which of the CAI's for the tiburon's were carb aproved, including the shark racing CAI. living in cali, the cops here check all that sutff and going legit is probably best. thanks
Old Mar 22, 2002 | 02:30 PM
Viper966's Avatar
as much as i know Things that are on the inudction side of things do not need to be carb approved, things that do are because the effect the exhaust side fo things, which cause smog and pollution, A CAI will not effect ur abilty 2 pass a sniffer test @ all
Old Mar 22, 2002 | 02:53 PM
In CALI, CAI's need to be CARB approved. None of the existing CAI's are CARB approved. (KORE, AOS, Injen, or Random Special)
The SR CAI is not out yet, so I cannot say if it will be carb approved.
Old Mar 22, 2002 | 02:59 PM
Viper966's Avatar
really Cali sucks..... here in NY we dont even have exhaust testing, is there any reason why any of the CAI's wouldnt pass CARB's requirments i dont see a reason why, and Random how are u passing anything
Old Mar 22, 2002 | 03:02 PM
Note: it takes time, patience, people skills, lots of $$$ and maybe even a little bit of bribe $ (dunno about that last one wink ) to get ANYTHING CARB Approved. If you never get pulled over you don't have anything to worry about and if you do it's just a fix-it ticket.
Old Mar 23, 2002 | 12:52 PM
HRD_Tiburon's Avatar
Some of the parts that I am working on I am looking into CARB approval. You have to have the emissions testing done a CARB approved test facility. The testing totals to be around $3000+ depending what you ae having done. Then after testing you have to send the results to the EPA and have a board approve it. If they require more data they will ask you to go through more testing at there expense. They will also have to have a copy of what is being tested to review also. If approved you get a CARB EO Number, if not more testing all over again.
Old Mar 24, 2002 | 11:20 AM
rx bandit's Avatar
that sounds like a lot of trouble. now i understand why all of the intakes aren't carb aproved. what products are you making, by the way, and when will they be available? thanks.
Old Mar 24, 2002 | 03:12 PM
Flux's Avatar
Probably only the AEM for a while (provided they ever actually release the thing)
