Idle Problems..
Old Mar 8, 2008 | 12:32 PM
mb499's Avatar
Ok two idle problems. First, sometimes it will go up to 2k for no reason when im in neutral or clutch is pushed in, and keep rev'ing between 2k and like 2200. Does it when Im sitting still, or say if I'm rolling to a stop. And now when I'm sitting there in neutral, it drops down to like 100 rpm's like it's going to die.
Also, one of my belts is making a squeeking noise like every revolution or so, I heard maybe it's loose but it seemed tight.
If it matters I have a dae-sung TPS.
Old Mar 8, 2008 | 01:16 PM
tib _500's Avatar
possible TPS, MAF, IAT(if we have one), or even IAC. try unpluggin all of them and see which effects it the most(this will trigger the CEL).
Old Mar 8, 2008 | 01:26 PM
Tibbychick's Avatar
Get yourself a Kefico TPS ASAP.
Old Mar 8, 2008 | 01:36 PM
TPS right away. Probably will fix it.
Old Mar 8, 2008 | 01:49 PM
StrikeEagle's Avatar
TPS!!
Oops, way too late...
Old Mar 8, 2008 | 02:27 PM
Lol, if it matters... That would have been one of the first questions. Its amazing how one of these topics come up like every week.
Old Mar 8, 2008 | 04:22 PM
mb499's Avatar
So it is TPS 100% for sure?
And how do I fix squeeky belt lol.
Old Mar 8, 2008 | 04:25 PM
javageek's Avatar
The squeeky belt is probably because of your low idle. Fix that first, you may not have to worry about the belt.
Old Mar 8, 2008 | 04:36 PM
tib _500's Avatar
well theres 3 different belts one is probily coming loose. if you tib has been wrecked check for a plastic under gaurd on your passenger side.
my tib the belt slips from water getting on it, due to the missing undergaurd(have one but been to lazzy too install).
also i would do what i said and just unplug everything one thing at a time(keeping only one unpluged) and see what sensor changes your idle the most my iac went out and my car idled 2000 for a long time and then i unplugged it and it went back down. now i changed it and it idles fine.
Old Mar 8, 2008 | 05:23 PM
mb499's Avatar
I'll try unplugging stuff tommorrow when its light out and I figure out where the things are. I know tps.
The guard, is it the same thing as on the drivers side that does/would somewhat protect a CAI? Like a splash guard.
