Clutch Burning Smell
Old Nov 10, 2007 | 04:40 PM
cleppe123456's Avatar
i was on a very big hill today and had to rev up high and give the car a lot of gas to get going. afterwards, i smelt a burning smell coming from the car that went away in a minute or so, i am assuming that the smell was the clutch? did i ruin the clutch? it still worked fine and all, but i am wondering if a burning smell from the clutch once in a while is ok? also, i had to use the emergency brake to help get going?? it doesn't ruin the e-brake when u use it to get going on a big hill now an again, right??
thanks
Old Nov 10, 2007 | 04:46 PM
It does not hurt the emergency brake to use it under any circumstances except while the car is moving.
You may want to deglaze your clutch. http://www.rdtiburon.com/index.php?showtop...&hl=deglaze You probly did not wear it enough to warp it.
Old Nov 10, 2007 | 05:04 PM
Alex01tib's Avatar
No, you may have shortened the life of your clutch a thousand miles or so, but it should be fine.
Also you shouldnt have to rev that high to get up any hill on any road...
