Help With Obd-2 Reader
Old Jul 24, 2007 | 04:52 AM
Does your TPS sensor position % show up on your OBD-II scanner?
Old Jul 24, 2007 | 10:00 AM
funkypc's Avatar
I think so, but I would have to double check.
Old Jul 24, 2007 | 11:13 AM
Jay-M's Avatar
Vehicle: 01 Tiburon
yes it does
it's sometimes called load %
what's on yer mind?
Old Jul 24, 2007 | 11:22 AM
Alex01tib's Avatar
Yah not sure what it would be called on the scanner, perhaps throttle position ( lol )
but its deflection on the SMT-6 and load % on the haltech so look for that too
Old Jul 24, 2007 | 11:41 AM
My throttle position does not deflect. The "absoloute throttle position" stays at 0% always on the obd-ii reader. I tested the unit and it checks out good.
I know that load is calculated from MAF value and temperature, as well as some other things.
Old Jul 24, 2007 | 12:24 PM
funkypc's Avatar
well, unplug your TPS and see if anything changes.
Old Jul 24, 2007 | 01:00 PM
No, there was no change on OBD-II reader, but there was a change to the idle. There are alot of different options for different cars. I need to know if absoloute throttle position is supported by our ECUs for output to OBD-II
I'm asking a really straight foreward question here... Does the absoloute throttle position sensor on your obd-ii reader work?
Old Jul 25, 2007 | 08:40 AM
alpineboarder's Avatar
Vehicle: 1999 Hyundai Elantra
Dumb question: is your TPS good? Could be it's not reading on your scanner because it shit the bed.
Old Jul 25, 2007 | 04:26 PM
Alright, seriously, someone go out to their car with their obd-ii reader and tell me if it reads TPS. I really want to know if you can get Absoloute throttle position % on a Tib.
Schphi: yes, i tested the fuxor and it came out good. I posted that up higher. I'm also running my nitrous system on the TPS. I'm not throwing codes, and it shows change on my multimeter with no deadspots.
I don't think there's any problems. I don't know if there's any need for concern
I really just want to know if the ECU passes TPS data to the reader. Does your OBD-II reader read the TPS % value?
Old Jul 26, 2007 | 10:04 AM
Jay-M's Avatar
Vehicle: 01 Tiburon
here's mine on idle
i don't know where i got this one from... but it still shows activity on the tps
so, yours show 0% on the scantool? did you try different softwares? it should be in the cd-rom i've sent you
