Valve Cover Gasket
Vehicle: 2011 Kawasaki ZX6R
Ok well there were multiple sets that my parts store had available so I picked up the 2 closest and I'll just return the one that I don't use. My car is a 98.
One set says its for 2.0L 97-98
The other is for 2.0L 97 to 10/31/02
Which do I use? They have different numbers for the valve cover gaskets...
This one has the spark plug seals.
Hmm, I've had my valve cover on and off several times and never replaced any of those seals, if they aren't leaking, I'm not replacing.
I'll see what shape they are in when I pop it open. If they look bad I'll replace them, if they look ok I'll use the gasket set that's cheaper(missing the spark tube seals). 1 set was $14 the other was $27
