Weird Stalling Problem, Just Started Happening
Old Jan 12, 2006 | 06:45 AM
What clutch you put in there?
Old Jan 12, 2006 | 10:00 AM
zhiryst's Avatar
if its doing it when you first start up, there's a chance it could be the TPS. when you first start the car, it sets the RPMS automatically, maybe that feature deactivates when you engage the clutch? Just an idea. At least its a simple part to swap.
Old Jan 12, 2006 | 10:16 AM
hamhead's Avatar
Could be just you stalling the car because your not used to the clutch yet... you might be used to it catching higher or lower.
But its kind of hard to diagnose over the internet of course.
Old Jan 12, 2006 | 10:49 AM
Jaws021's Avatar
i had the clutchmasters stage 4, so its not the clutch.
Maybe its the driver?
Stage 4s are very sticky... give it some more rpm.....
do you hear any grinding?
Old Jan 12, 2006 | 01:37 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
maybe Idle Speed Actuator?
Old Jan 12, 2006 | 02:34 PM
Agarwal's Avatar
Why do you want other thoughts, considering that bleeding the slave cylinder is a 10 minutes job? Go do that, and if it stills does it, come back here.
