Overdriving Accessories
Old Feb 19, 2006 | 12:39 AM
would i run into any problems if i overdrive the accessorys?
dont ask cuz i wont tell you
Old Feb 19, 2006 | 04:33 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
overdrive, you mean they will spin faster?
if so it will be ok for low and mid RPM, I'm not sure about high RPM, cause p/s pump, water pump and alt. were designed to work in specific RPM range.
Old Feb 19, 2006 | 09:28 AM
hmm thats true at high rpms it might cause a problem i would hate to burn out the alternator....
i wonder if i can overdrive the crank and install underdrive pulleys for the accessories would that basically counteract anythin but would a overdrive pulley cause a problem on the motor itself?
Old Feb 19, 2006 | 10:38 AM
more drag... think of it like a 10 speed bike (or a 21 speed mountain bike) underdriving is like being on the small crank ring and the large sprocket in back. You can spin your heart out and feel little drag. Makes for great acceleration.
Overdriving would be like having the chain on the large ring and the small sprocket in back. LOTS of power is needed to spin the pedals.
Old Feb 19, 2006 | 10:58 AM
Tiburonsrule's Avatar
Vehicle: 2000
Old Feb 19, 2006 | 11:50 AM
hmm i think a little drag will be ok i guess... hehe
oh and tibsrule you have NO idea what im up to...
Old Feb 19, 2006 | 03:36 PM
Vehicle: 2000
i cant think of anything your right. good luck with it anyway
Old Feb 19, 2006 | 03:44 PM
Dmitry's Avatar
Dave, everything should be fine if you use same gear ratios (acc pulley diameter divide by crank pulley diameter). If you use bigger crank pulley - use bigger accessory pulleys.
Old Mar 4, 2006 | 11:12 PM
so um... anything come of this top secret project yet?
Old Mar 5, 2006 | 12:12 AM
nope not yet
its not a NA mod so keep that in mind...
