Lsd Inserts
Old Mar 10, 2006 | 01:51 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I found LSD inserts for $225.
it should be installed on stock differential.
Anybody tried it?
Old Mar 10, 2006 | 01:53 PM
interesting... im waiting for some input on this
Old Mar 10, 2006 | 04:37 PM
thats the phantom grip thingy its isnt a lsd its basically a giant band aid to allow both tires to turn
keep this past like 180 hp i think and your diff is gonna 'splode
Old Mar 10, 2006 | 05:06 PM
Raven997's Avatar
Vehicle: 99 Tibron
thast what i have been told
Old Mar 10, 2006 | 09:47 PM
Denisst99's Avatar
Diff won,t explode, i've bee nrunning one for at least 3 years al lyear around without any problem,
but i feel it's "limited" to around 200 hp, more then that it won't have the bite to hold both wheels
with time it will also loose some bite (polishing of the gears and block, lost of spring tension)
Old Mar 11, 2006 | 01:05 AM
Dmitry's Avatar
^^^ do you recommend this thing?
I want LSD mostly for winter use.
Old Mar 11, 2006 | 08:08 AM
Oh, they will make your diff explode. It happened to Onpol years ago at around 250 HP I belive.
Do a search for 'Phantom Grip' here and at HA.com
Old Mar 11, 2006 | 10:50 AM
Mad_john's Avatar
GARBAGE. d dont you think about getting that that is crap it will fall apart and when it does it will take everthing with it...
Old Mar 11, 2006 | 01:49 PM
Dmitry's Avatar
John, I was interested how that metal box with some holes can make an LSD from stock LSD... it doesn't look reliable.
Anybody know how much would be Santa Fe LSD? and will it fit directly?
Old Mar 12, 2006 | 01:54 AM
Mad_john's Avatar
^ i am working this issue now, i am going to have a shop here give that a try.. i will keep eveyone posted
