Cant Shift Into Reverse
Old Mar 29, 2006 | 10:20 AM
Dweet's Avatar
Ok well it appears my cooling problem was in fact an air bubble but now that i went to go take it for a test drive i cant put it in reverse, however every other gear will shift fine.... suggestions?
Old Mar 29, 2006 | 10:26 AM
zoned019's Avatar
Vehicle: 97 Tib
First I'll state the obvious....put it in first and let off a little bit so the car comes forward, then back in neutral and double-clutch into reverse.
Old Mar 29, 2006 | 04:19 PM
You haven't recently messed around with your backup lights switch (the one in the tranny) by any chance, have you?
