Transmission Filter?
Old May 15, 2006 | 09:58 AM
Screwdriver's Avatar
Didn't realize we had a tranny filter. Anyone changed theirs recently? I can't imagine it being an easy thing.
See Amsoil's application guide below. I was just about to purchase their transmission lube and saw it.
1998 HYUNDAI TIBURON 2.0L 4-cyl VIN Code F DOHC
BOSCH SPARK PLUGS
All submodels
Plug......B4418[1]
Wire......B09466
1. Do Not Gap. Gap is not adjustable.
BOSCH WIPER BLADES
Driver side......B40922
Passenger side......B40918
FILTERS
Oil Filter......EaO20/SDF20
Air Filter......46318
Fuel Filter......33229
Trans......58601
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above 32°F......20W-40, 20W-50
Above -9°F......10W-30, 10W-40, 10W-50
Below 95°F......5W-30, 5W-40
Manual Transmission,.....GL-4
75W-90, 75W-85W
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Fluids
Power Steering Fluid.....AF2
Synthetic Automatic Transmission Fluid
Torque-Driveâ„¢ Synthetic Automatic Transmission Fluid (ATD)
Brake Fluid.....HB
Clutch Fluid.....HB
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
CAPACITIES
Engine, with filter..........4.2 quarts[1]
Cooling System, Initial Fill..........6.4 quarts
Automatic Transmission, Total Fill..........7.1 quarts
Manual Transmission, ..........4.6 pints
1. After refill check oil level.
TORQUES
Oil Drain Plug.....26-32 ft-lbs
Manual Transmission
Fill Plug.....22-25 ft-lbs
Drain Plug.....22-25 ft-lbs
Old May 15, 2006 | 10:02 AM
if you have a auto you have a filter
if standard no filter
Old May 15, 2006 | 10:16 AM
Thanks. It's 2.2 Quarts of Manual Tranny oil, right?
Old May 15, 2006 | 10:21 AM
well i had 3 and used about 2 and a half so yes lol
