Removing Main Pulley... Timing Belt Replacement
Old May 2, 2006 | 06:34 PM
Call_to_arms84's Avatar
Got started on my timing belt and water pump replacement and I hit a snag. I cant get the main pulley off the end of the crank, i can get a breaker bar on it and turn the motor over, but that doesnt do me any good. I got my shop jack out and lifted it against the pulley with a 2x4" but it still spun. I am in search of some sort of a clamp or a vise to hold the pulley, im sure the tool for it has exist, somewhere, if I cant find that im gonna buy an airgun, ive been putting off puying one until i needed it, now I need it. How does everyone else do this? is there another way to pry against the puller to keep it from moving?
Old May 2, 2006 | 07:10 PM
zoned019's Avatar
Vehicle: 97 Tib
If cranking the engine doesn't work then .... you must be doing something wrong, that puts a lot of torque on it.
That's what most people do, it should work..
Old May 2, 2006 | 07:11 PM
almost 2500 posts... going to say this once.. and only once.. SEARCH! I have mentioned how to do it several times in the last couple of months.
Zoned is right about cranking the engine.. just make sure it cannot start when you do it.
Old May 2, 2006 | 07:20 PM
SilentSecret's Avatar
Vehicle: 1997 Hyundai Tiburon
put your breaker bar on the ground and crank your engine. pop it spins the bolt right off. when you do it make sure the belt is still on and take the plug wires out b4 trying. this way the motor will spin but not start your car. always worked for me.
or get a air gun.
Old May 2, 2006 | 07:27 PM
mine was on there good also i ended up using a really really large pipe ( like 8 feet long) and i used my weight to get the dam nut off (250 lbs of torque lol)
and i had airtools, lift, etc
Old May 2, 2006 | 07:38 PM
col96fx's Avatar
Vehicle: Hyosung GT650
I tried cranking the engine & also the 1/2inch rattle-gun, but mine wouldn't come off, so I ended up getting hold of a BIG-ASS compressor and a 3/4inch rattle-gun & that shifted it.
Old May 2, 2006 | 10:15 PM
^^rattle gun wtf? lil bit of hillbilly slang there?
its a impact gun. 1/2 inch should have done it. you do know that you have to add oil to the line sometimes rite?
so call? did you get it?
Old May 2, 2006 | 10:39 PM
col96fx's Avatar
Yes I do know how to use a rattle-gun (that's what we call them down here). I did get it off, but it was fvckin tight.
Old May 2, 2006 | 10:57 PM
'treezy's Avatar
anyone knoe the torque specs for puttin it back on?
Old May 2, 2006 | 11:01 PM
ya... tightenthecrapoutofit.
