White Smoke And High Idle
Old Jan 17, 2006 | 12:35 PM
Dweet's Avatar
quick couple questions anyways i just finished installing the engine a cpl weeks ago and ran into a problem, my car idles high.. around 2K and after it heats up there is white smoke coming out of the thermostat housing... anyone got answers?
Old Jan 17, 2006 | 01:58 PM
Minor oil leak at the back or side of the engine that's getting near the thermostat and burnin off?
Old Jan 17, 2006 | 02:07 PM
Dweet's Avatar
the smoke is white, no blue tint to it so i dont think its oil burning, also i hear a hissing sound coming from that area as it heats up, im hoping i just need to replace that gasket and ill do the thermostat replacement at the same time as well but i was just seeing if it might be something else
Old Jan 17, 2006 | 02:08 PM
Got a small mirror?
Old Jan 17, 2006 | 02:10 PM
rallyman's Avatar
White smoke must indicate burning coolant so there must be a leak and its burning off once the engine gets hot. You better replace the gasket and make sure its installed and sealed properly and see if that fixes the problem.
Old Jan 17, 2006 | 02:19 PM
Jaws021's Avatar
dont over torque those bolts or the will strip off the block
just replace the gasket..
Any dealer should have it in stock.
