1.8 Cam Swap
Old May 30, 2006 | 04:32 PM
bumpintibby's Avatar
I'm planning on doing a 1.8 cam swap (among other things) and I was wondering
if you could remove just the intake cam without removing the exhaust.
Old May 30, 2006 | 04:37 PM
kb5133's Avatar
Yes you can. You may need to remove the bearing cap on the #5 exhaust journal so that you can remove the timing chain guide. I say may because mine did not have an upper chain guide. ???)
Once you remove all the caps on the intakse side you'll be able to lift it up and take the chain off. If you haven't already check out the 1.8l cam DIY in the DIY forum.
Old May 30, 2006 | 05:16 PM
Sweet!! I thought you could, but I wasn't sure.
Old May 30, 2006 | 06:09 PM
I only pulled the intake cam with I did mine. Did not have to touch anything on the exhaust side.
