Engine Mounts (rubber).
Old Jan 25, 2006 | 04:38 AM
renante's Avatar
local suspension workshop diagnosed this problem.
engine mounts located centre front/rear is wornout.
slight shuddering noise when accelerating on low gears and low rpm
my is 8 years old, so this type of replacement was due anyone.
I just purchased good secondhand set from the wreckers to get through.
Has anyone tried the polyutherane plastic?
Old Jan 25, 2006 | 06:25 AM
Yup. Lots of folks have them from Kspec.com . Or you can do it yourself and fill your stock ones.
Old Jan 25, 2006 | 07:31 AM
"window weld" is what they use. seems to give really good results for the money.
Old Jan 25, 2006 | 11:15 AM
Jaws021's Avatar
I used some industrial ones that killed my wheel hop completely
Check the sale forum.. i was selling them... actually i still have them tongue.gif
Old Jan 25, 2006 | 03:12 PM
renante's Avatar
thanks guys.
REDZMAN I've placed an order for one engine mount for rear gearbox.
Jaws021 pm us the cost of US airmail to australia.
I've placed a reply on your forum thread, I'll need them for spares.
Old Jan 26, 2006 | 10:53 PM
renante's Avatar
just replaced the faulty centre engine mounts.
and temporarily replaced them with the ones from the wreckers.
old mounts
rubber was cracked around the bolt sleeve
for both the front and rear.
Old Jan 27, 2006 | 06:34 AM
Mad_john's Avatar
go with the yaya, that is you best bet, if you go to hard you will crack you front pannal aka frount frame...
