Engine Mounts
Old Mar 29, 2006 | 03:21 PM
IJSTBRNDU's Avatar
Is there any easy way to replace the engine mounts
i checked webtech but no luck only how to do roll stops.
also, whats the best way to pop out bushings and replace them?
Old Mar 30, 2006 | 09:53 AM
JonGTR's Avatar
Only way is to use a hydrolic press. It's actually pretty easy to do, you just need the press.
The F/R mounts need to be taken off by removing the center brace.
Old Apr 4, 2006 | 11:41 PM
Call_to_arms84's Avatar
I just finished doing this, dropping the crossmember can be a PITA, it is held in with 4 big bolts about 4" long that go right into the chassis. Mine needed about 150 ft/lbs for the whole legth of the bolt, other than that there is 2 10mm bolts at the front that hold the engine compartment covers inplace and the actual bolts that go through the motor mount, and then it drops out.
Old Apr 4, 2006 | 11:45 PM
Alex01tib's Avatar
I removed the crossmember when i installed my turbo, didnt think it was that much of a hassle, the front motor mount was a little bit of a pain but not too bad.
Old Apr 5, 2006 | 01:08 AM
renante's Avatar
Mine was easy and straightforward.
I payed $25 for the labour to get the Local Bridgestones Dealer to change the engine mounts.
they also had a Car hoist. It took them approximately one hour to complete.
Old Apr 5, 2006 | 01:25 PM
JonGTR's Avatar
QUOTE (Call_to_arms84 @ Apr 5 2006, 12:41 AM)
Probably cause you didnt take the weight of the motor off the support member. ugh.gif
When I take it off, I prop it up on the opposite side and basically use my bare hands to unscrew them.
Old Apr 6, 2006 | 04:52 PM
tibu971.8L's Avatar
Did ya'll change the 4 mounts? I thought Kspec didn't reccommend this option because you would get some serious vibrations up to the cockpit.
