Help With Flywheel Crank Pilot Size
Old Jan 23, 2006 | 06:13 PM
tibbypimpin's Avatar
Vehicle: 1998 hundai tiburon se
I know that there is 2 diff sizes for the flywheel.97 to 7-99 is 41mm and 7-99 and up is 35mm.Right.so why would a seller tell me that there is no diff.well here is the email
Hello,
Thank you for choosing eClutchmaster as your clutch kit provider and
inquiry.
The flywheel for 1997-2001 Hyundai Tiburon uses same flywheel and same crank
pilot size.
This flywheel is good for any Tiburon 2.0L '97-'01 production regardless
crank pilot size.
Email back to us for further assistance and buy with confidence.
Regards,
Online Support Team
eClutchmaster
Visit our website http://www.eclutchmaster.com
(213) 365-2899
Question from tibby_pimpin
Item: HYUNDAI TIBURON ELANTRA 11LBS LIGHTWEIGHT FLYWHEEL (8031561805)
This message was sent while the listing was active.
tibby_pimpin is a potential buyer.
Hello I was woundering,I have a 1998 tiburon and I know that there is a diff
in the flywheel from 97 to 7/99 model year the crand pilot is 41mm and 7/99
to present the crank pilot is 35mm could you tell me witch one this is and
if ypu carry the 41mm one for the 1998 hyundai tiburon 2.0.thanks scott k
Old Jan 23, 2006 | 10:46 PM
Denisst99's Avatar
they might use a "spacer/adaptor" like the VHR one...
those look more like replica rather then a " real " product,
might be a simple copy of the vhr flywheel
