Easy Place To Tach?
Old Feb 1, 2006 | 05:30 AM
I'm looking to cal 3 sets of TACHs. Is there somewhere i can freq clamp, or wirestab to get readings? I tried to freq clamp cyl#1#2#3#4 each one gave me eratic readings. I'd just like to find somewhere simple for a one time op. I know about the ECM #40 and the one on the back of the gauges. Is there somewhere else that can be probed in the engine compartment or with the dashboard removed?
Old Feb 1, 2006 | 05:49 AM
1. Why? Is your stock tach broken?
2. Aftermarket tach's are R I C E.
3. Why are you doing 3 Tachs? Afraid you might have 2 of them break when running? LOL
4. Search. There's 2 very easy places to get it from.
a. Tach Sig screw on the back of the instrument panel.
b. Tach sig wire enroute to the ECU.
Old Feb 1, 2006 | 10:55 AM
Actually, I bought a seccond set of gauges to mod and then stick in my car. I received another set of gauges from patreezy for modding his, now all 3 have needles pulled off and I was hoping to make it quick and painless to cal them.
I did search, and i came up with that. I was hoping i could get it from an OBD pin or on coil somewhere so i could make it all really simple. I'll post if webtech turns up something.
Old Feb 1, 2006 | 11:37 AM
its wire #5 on 101-2. but the pin readouts on the back of the cluster are wrong, or something like that. they are reversed. its been so long, but i did make a post about it a couple years ago in the reference section.
Old Feb 4, 2006 | 06:33 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
If TCM is signal from tachymeter, then you can find it in OBD-II (D-Link) port under the dash. It's pin #1.
But check WebTech before. Electrical Trouble Shooting -> Engine Electrical System -> General -> Data Link Details
Dmitry's Avatar
