Transmission Removal
Old May 12, 2006 | 09:51 PM
tblakea04's Avatar
Vehicle: 01/Hyundai/Tiburon
does this removal apply to 01 too?
http://www.rdtiburon.com/index.php?showtop...mission+removal
Old May 12, 2006 | 09:57 PM
NemainTib00's Avatar
I'm pretty sure it's the same
Old May 12, 2006 | 10:09 PM
tblakea04's Avatar
ok coo thanks,....anywhere with a removal with pics?
Old Jul 30, 2006 | 03:58 PM
divaracer2000's Avatar
Ok so I did everything explained here and then some. I can't find anything to help me take the tranny off of our 2000 Tibby. I comes out about an inch and ahalf but thats it. As I try and pull it off it pops right back. ANy help with this would be greatlt appreciated.
I read somewhere that you have to lift the clutch assembly that is bolted to the tranny and turn to get it off. Turn what? the tranny or the assembly? Am I doing this right? help please. mad.gif
Old Jul 30, 2006 | 04:28 PM
Alex01tib's Avatar
IS it an auto or a stick?
Because if it is a stick you need to unbolt and remove the release arm
Also there is a bolt that keeps the metal flange onto the bell housing but isnt directly bolted onto the block so you will be able to move it a bit but not fully remove it.
Also with the crossmember removed you can lower the engine and it will give the tranny more clearance if thats your problem.
There also pins that support the weight of the tranny when there are no bolts in, you need to pull the tranny off of those before it will come out.
Try that stuff and see where you stand.
Old Jul 31, 2006 | 03:50 PM
Can you post a pic of what you are telling? The release arm is the part that one of the cables hooks into right? The part on top back side of the tranny right? Sorry for the basic questions but I am new to the Hyundai engine and tranny department.
by the way it's a stick.
Thanks
Old Jul 31, 2006 | 04:07 PM
iQfOreVa's Avatar
Vehicle: 2012 Mustang GT
that should help with pictures
http://hmaservice.com/webtech/iindex...d=12833#_12833
Old Aug 5, 2006 | 07:47 AM
It's been over a week and I still haven't got a user ID and password sent to me. Does it usually take this long?
Old Aug 5, 2006 | 08:53 AM
Arcy's Avatar
Vehicle: 2000 Hyundia Tiburon
RDtiburon has a Username and Password setup for the site.
DIY Websites
It can be found there^
Old Aug 5, 2006 | 12:40 PM
OK so I am able to get on and print the instructions but it is still not telling what I have to do to take this thing off! Am I just missing something?
