Outlaw Thermo Spacers
Old Feb 24, 2006 | 03:19 PM
NightShark's Avatar
The thermo spacers for the intake manifold is bored out bigger than the actual openings on the runners, is that supposed to be how it is? i figured it would flow better if it was the same size as the opening..
also.. is the outlaw kit that was purchased in the GB supposed to have studs with them?
Old Feb 24, 2006 | 03:37 PM
BlackTibby00's Avatar
You had a choice of ordering them with or without studs.
Old Feb 24, 2006 | 05:46 PM
QUOTE (NightShark @ Feb 24 2006, 03:19 PM)
Yes.
Ehh, maybe, but if you get a P&P done, then you'll be fine.
Only if you ordered the kit with studs.
Old Feb 24, 2006 | 07:12 PM
NightShark's Avatar
if i get a P&P done it wont work either cause the amount that the spacer is off is not even..
Old Feb 24, 2006 | 07:13 PM
Might wanna contact Outlaw then, mine was even all the way around.
You can get it ported with your P&P.
Old Feb 26, 2006 | 08:51 PM
NightShark's Avatar
i have an airram
