A Couple Of My Oil Testing Results
Old Mar 2, 2006 | 09:47 PM
Korean_Redneck's Avatar
Vehicle: 1999/Hyundai/Tiburon
I recommend you guys doing a Oil anaylsis sometimes.
February of 2005
Some notes before you read the chart:
-Oil sample was taken at the end of the drain
-Car was driven hard in COld weather
-stop-go traffic james everyday
-HIghway driving everyday
-This oil was sampled right before my major 90k tune up and before my Auto-Rx flush
Hyundai Tiburon FX, 2.0 litre 4 cylinder engine. No make up oil, Supertech Semi Synthetic oil 10w30 with Supertech ST6607 Oil filter.
Nothing too unusual showed up here. All wear read at or below averages, which is a very good indication of normal wearing parts and careful operation. Fuel dilution has lowered the viscosity and flashpoint slightly, though it isn't enough to call a problem at this point. The TBN was okay at 3.3, so the oil still has some life left. At 87,266 miles, we think this engine is doing well. Try 5,000-5,500 miles on the next oil. It isn't necessary to sample during the Auto-RX and rinse pahse unless you want to. -Blackstone
Aluminum 2
Chromium 2
Iron 7
Copper 3
Lead 1
Tin 1
Moly 2
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 1
Boron 2
Silicon 5
Sodium 2
Calcium 2207
Magnesium 8
Phosphorus 880
Zinc 996
Barium 1
Late 2005
Notes:
-10w30 50% Valvoline Conv/50% Valvoline Maxlife Synthetic
-1 quart Shell Conventional makeup oil(My engine doesn't like Shell Oil Conv, my HLA's are noisy with this oil)
-13,000 miles on my Purolater Air filter
-Advance Auto Parts Oil filter
-oil is 4 months old, driven in the winter
-Car has 103,000 miles
-Drove 70% City and 30% highway
No problems showed up in the sample from your Hyundai. All wear read well belowaverages for this type of engine, which is a very good indication of normal wearing parts and careful operation. Insolubles (oil oxidation due to heat, use and blow-by) were low at 0.3%, showing good oil filtration. No fuel dilution or anti-freeze was found. Silicon was normal at 5 ppm, so your air filtration is still getting the job done. This engine appears to be doing well.
Aluminum 2
Chromium 0
Iron 2
Copper 1
Lead 0
Tin 1
Moly 91
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 1
Boron 57
Silicon 5
Sodium 0
Calcium 2451
Magnesium 10
Phosphorus 674
Zinc 797
Barium 0
SUS Viscosity: 59.2
Flashpoint in F: 375
Fuel %: <0.5
AntiFreeze: 0
Water: 0
Insolubles:0.3
I'M VERY HAPPY WITH THE RESULTS except the fact that my car is burning 1 quart every 4,500 miles. I think it has to do with Synthetics. I get less oil consumptions with straight conventional oil.
Old Mar 3, 2006 | 01:03 AM
zoned019's Avatar
Vehicle: 97 Tib
Okay, you should post up some info on what all that really means, I wouldn't be able to tell the difference between a really good and really bad analysis, what does each of those minerals mean/do?
I can probably say I'm not speaking for just me either (unless there's lots of oil experts on here..)
Old Mar 3, 2006 | 05:51 AM
Wow man, you feeding your car Viactive or just giving it some milk every day?
Old Mar 3, 2006 | 10:22 AM
Vladimer's Avatar
Vehicle: 01 Tiburon SE
were abouts can you get a oil sample done for your car? never heard of it being done around here
Old Mar 3, 2006 | 12:12 PM
Oil Anaysis is very important. Go here http://www.blackstone-labs.com/ and order a free sampling bottle. And go here http://www.bobistheoilguy.com if you want to know what each of the metals means. Iron is usually wear on the Pistons, I think copper has to do with bearings or something. Silicon is like Sand(indicates if you have a good air filter). It cost $20 to sample and a extra 10$ if you want them to find out if your oil has some life and additives left. I used the cheapest oil on the market on my first test (walmart Supertech) and I got awesoem results. They recommended me using that oil until around 5,000-6,000 miles.
http://theoildrop.server101.com/ubb/ultima...p?ubb=forum;f=3
Here are a bunch of cars and types of oil people have done.. Look at somebodies brand new Nissan Titan. You'll be scared to look at his results!!
Old May 26, 2007 | 05:37 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
hey man check my thread !!
www.rdtiburon.com/index.php?showtopic=22688
