Idle And Acceleration Problems
Old Mar 28, 2006 | 05:28 PM
KCVoRTeX's Avatar
ok my car was misfiring and I replaced the plugs and plug wires. Now it's not idleing properly and won't accelerate much if I'm below 2k rpms. Also it will almost die if I just let off the gass from 3k rpms. (the idle will drop to 500rpms) can anyone tell me wtf is wrong with my tib?
Old Mar 28, 2006 | 05:32 PM
mb1604's Avatar
you touch the maf at all?
Old Mar 28, 2006 | 05:43 PM
Sounds like my RD1.
You check your TPS?
Old Mar 28, 2006 | 05:46 PM
KCVoRTeX's Avatar
didn't touch the MAF.... how do I check the TPS.... the only thing that I could tell you about it is it's still there..... I got my hands on an OBD II reader and it did pull a code on the TPS.... what do I do to fix it?
Old Mar 28, 2006 | 05:50 PM
mb1604's Avatar
probably get a new one lmao.gif but ya once the tps goes. you usually have to get another one.
Old Mar 28, 2006 | 08:31 PM
try ECU reset first. maybe it will clear bad values.
Old Mar 28, 2006 | 08:59 PM
QUOTE (kcvortex @ Mar 28 2006, 05:46 PM)
First, double, then TRIPLE check your MAF.
Look at your TPS. Ensure both screws are there.
Then see brand it is. If it's the Dae Sung, Hyundai has to replace it for free with a Keifco.
Just call up the dealer, tell them what code you have, and that you have an old Dae Sung TPS (I bet you do).
Make an appointment and get in and get it replaced. It is FREE. Make sure you tell them you looked up the TSB on it and you know it's free.
Old Mar 28, 2006 | 11:16 PM
KCVoRTeX's Avatar
I looked at the TPS and it looks fine.... and it is a Keifco. I ordered a new one from o reileys but it won't be in until thursday.... =(
Old Mar 29, 2006 | 12:23 AM
Alex01tib's Avatar
mods?
if you have a cai id check for leaks, it sounds like the maf isnt getting a correct reading on the air. if you have a cai tighten the couplers. if you have a stock box, make sure its not leaking.
check the wires on both the tps and the maf, as well as the arrow on the maf is pointing in the right direction.
Old Mar 29, 2006 | 05:09 AM
QUOTE (kcvortex @ Mar 28 2006, 11:16 PM)
That one is the best but it can go bad also.
Why haven't you taken it to the dealer?
