Idle And Acceleration Problems
Old Mar 29, 2006 | 06:15 AM
Hyundaidb883's Avatar
there's a nice flow chart for dtc p0121, p0122, & p0123 (tps codes) on the hmaservice website that you could follow.. i think i've ran into a problem where if your tps was either tampered with or just misadjusted that you will get problems like you're experiencing right now. it's worth a shot to follow the chart to the best of your ability. try to set the tps to the right specs and see what happens, also clean your throttle body right after you reset the tps. you'll need a dvom to set the tps.
Old Mar 29, 2006 | 08:44 AM
WTF is a DVOM?
Old Mar 29, 2006 | 11:50 AM
KCVoRTeX's Avatar
The dealer said it would be $156 + tax for parts and labor..... $60+ dollars just for the part.... screw the dealer.
Old Mar 29, 2006 | 12:15 PM
That's because you allready have the Keifco.
I'm assuming your warranty is gone?
Old Mar 29, 2006 | 04:47 PM
KCVoRTeX's Avatar
second owner and car is at 73k
I have a CAI and I checked for leaks and found none
Old Mar 30, 2006 | 04:52 PM
KCVoRTeX's Avatar
was looking at the wrong thing.... I did have a dae sung.... but I replaced it now and the car still isn't running right and it's still throwing a p0121 code
Old Mar 30, 2006 | 05:39 PM
Hell, call up and see if you can get it as a "Goodwill" replacement, it IS under TSB from Hyundai.
You replaced it, but with what?
Did you reset your ECU afterwards?
Old Mar 31, 2006 | 04:26 PM
KCVoRTeX's Avatar
replaced it with a kefico and then reset the ECU.
stupid edit going away after so many hours... I hate looking like I'm double posting....
but here's an update... cars fixed... and I'm a moron... While messing with my intake to see how hard it was going to be to install my air ram.... I put the MAF on backwards..... someone slap the stupid out of me please kthx
ok I'm going to hopefully put my air ram on tomorrow.... and hopefully I'll put everything on the correct way... I'll take lots of pictures of the install since there really isn't much on a DIY for the air ram
Old Mar 31, 2006 | 05:32 PM
QUOTE (mb1604 @ Mar 28 2006, 05:32 PM)
you touch the maf at all?
QUOTE (kcvortex @ Mar 28 2006, 05:46 PM)
didn't touch the MAF....
QUOTE (REDZMAN @ Mar 28 2006, 08:59 PM)
First, double, then TRIPLE check your MAF.
QUOTE (alex01tib @ Mar 29 2006, 12:23 AM)
if you have a cai id check for leaks, it sounds like the maf isnt getting a correct reading on the air. if you have a cai tighten the couplers. if you have a stock box, make sure its not leaking.
check the wires on both the tps and the maf, as well as the arrow on the maf is pointing in the right direction.
I should ban you for a week. We PUSH that because it happens all the time, to lots of folks. And guess what? They are all POSITIVE it's on the right way.
QUOTE (kcvortex @ Mar 31 2006, 04:26 PM)
You CAN'T DOUBLE POST ANYMORE!!! IT'S PHYSICALLY IMPOSSIBLE!!!
