Fidanza Cam Gear
Old Mar 16, 2006 | 10:03 PM
landcruiser06's Avatar
I have a 2.0 tib, I was thinking about installing a 1.8L cam and ecu. I was wondering if I needed the 1.8 cam gear or 2.0 cam gear?
Old Mar 16, 2006 | 10:22 PM
zoned019's Avatar
Vehicle: 97 Tib
All you need is the cam/ecu.
Why are you putting in different gears too?
Old Mar 16, 2006 | 10:33 PM
SilentSecret's Avatar
Vehicle: 1997 Hyundai Tiburon
well.. fidanza makes only one adjustable timing cam gear for both 1.8 and 2.0 and doesn't make a cam gear/ exhaust gear. so either way its the same cam gear.
good luck
Old Mar 17, 2006 | 09:55 AM
So you dont think I need the cam gear? I just thought it looked cool, and has to be better than stock
Let me know
Old Mar 17, 2006 | 10:34 AM
zoned019's Avatar
Vehicle: 97 Tib
I suppose it does look cool, but who's going to see it?
It's used because it can be adjusted...unless you put in some really agressive cams or something I don't see why you'd need it.
Learn what stuff does before you plan to waste your money on it...lol.
