1.8 cam and 1.8 ecu...... together?
Hi... i have a couple of questions about this...
I know til now that if i install a 1.8 cam in my 2.0 L i will have better response... that is ok until this.
about the 1.8 ecu, i know that i will also have better performance with this.....
BUT if i install this two together? what would happen? i will have even more perfomance or together this two i will have the power of a 1.8 engine?
well and for last i want to know if these 1.8 mods in a 2.0 works from a 1.8 MAtrix? or the ecu aswell.
Do you know that is there a matrix from hyundai right?, here where I live there are a lot of it... and recently one friend just crashed and the ensurence are going to pay instead repair ... so this is why I ask.
hope you can tell me about this.
ok they will work together, what i tried to meant is if I install both of them would i get the power of a 1.8L ( 130 hp ) or i will get more than the 2.0L ( 140 hp ).....
and is it the same the engine of the 1.8 elantra and the 1.8 Matrix? or it wouldnt work with this matrix 1.8?
thanks
thanks
i have never seen the matrix
and no you will probably see around 125 whp with the cam and the ecu alone
more if you have other stuff
130 and 140 are flywheel hp
so maybe it would be better but nobody tried this before, right? how much should I get with the 1.8 cam from a elantra and how much from the ECU?
i dont know if I try this, because here i dont have dyno, i will have to drive it and go to the track to try it, but i dont know if I should or better not.
The Matrix is think
has a 1.8 L DOHC with 130 hp to the flywheel of course.
should I try o not?
The Matrix is think
should I try o not?
