Flywheel
Old May 10, 2005 | 01:42 PM
TiburonWao's Avatar
Hi...
What is the difference between
http://shop.hyundaiperformance.com/shop/it...hp?i=FID_193241
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...7971755495&rd=1
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...7973693719&rd=1
Can I bore the Flywheel to lower it's weight??? or do something else ??
Old May 10, 2005 | 02:20 PM
05GLI's Avatar
I wouldn't bother with aluminum flywheels. They break easier than stock. Just have some machine shop (or you can DIY) lighten your stock flywheel.
Old May 10, 2005 | 02:23 PM
brian01tib's Avatar
I dont have a man but the aftermarket flywheels have helped performance and gas milage, Ive heard the 1.8 is lighter than the 2.0 also
Old May 10, 2005 | 02:37 PM
Jaws021's Avatar
the difference is about 100 dollars..
enjoy.
I would not worry about a flywheel breaking... unless your going for uber tremendous power...
Old May 10, 2005 | 02:42 PM
05GLI's Avatar
I have seen aluminum flywheels break on many cars that do not have tremendous power, such as an RSX Type-S with only a cold air intake and exhaust. It shouldn't be too hard to find someone who can lighten a stock flywheel or a company who already offers OEM flywheels that are lightened.
Old May 10, 2005 | 02:45 PM
hamhead's Avatar
^^ Jaws has it covered for you. I wouldn't worry about a flywheel breaking either, considering the power most Tibs here put down. wink1.gif
Old May 10, 2005 | 02:46 PM
TiburonWao's Avatar
I asking this because I know a guy who has an BMW M3.... after he put a lightened flywheel, he loos 1 second of his E/T. He thinks it happened because thats because the car REV UP to fast without putting that power to the road....
So I'm thinking on lightened a little... but I don't know how much...
Old May 10, 2005 | 02:48 PM
Jaws021's Avatar
Your right... ive seen horror pictures of a couple of 4g63s..
Luckly we have not had any problems with broken flywheels. Stock or 300whp+...
The fidanza weighed about 8-9lbs from what i remember... The stocker was 16lbs if i remember right...
Old May 10, 2005 | 02:56 PM
hamhead's Avatar
No reason to lose E/T with a lightened flywheel... he just can't drive. Rev up too fast without putting the power to the road? LOL lol.gif
Like I've said many times, it just takes some getting used to a lightened flywheel/stronger clutch set up. The Tib was made for economy and ease to drive, not scrounging HP out of the engine at the expense of drivability.
Old May 10, 2005 | 03:57 PM
QUOTE (TiburonWao @ May 10 2005, 03:46 PM)
BMWs along with most eurpoan cars use dual mass flywheels that dampen the vibrations of the engine from the transmission and the body of the car. While great for noise/vibration/ and harshness, they such for all out performance.
As for your friend losing ET due to a lighter flywheel. He needs to learn to drive it. He is either overrevving and spinning the wheels, or he is giving too much clutch and not enough throttle and bogging.
