1.8l And 2.0l Engine Rebuild Kit Intertangable?
Old May 31, 2005 | 04:40 PM
buffbentley's Avatar
Would an engine rebuild kit for a 1.8L tib work with the 2.0L? I know the pistons and rings will ( and bump up compression too) but will the bearings, timing belt etc work? Here is the link, thanks!
http://www.rpmmachine.com/enginerebu...yundaitop.html
Old May 31, 2005 | 04:52 PM
albert's Avatar
Timing belt will not work. 1.8L block is shorter so 1.8L timing belt is shorter.
bearings and rings will
Unless your pistons are shot, I would re-use your existing pistons....
