another bogging down question!
Old Mar 12, 2005 | 06:05 PM
Solohan50's Avatar
Default another bogging down question!
alright all you hyundai gurus, i posted awhile back that i was having problems bogging down, and it turned out that it was my spark plug wires. now, it feels like it was acting before. if i give it more than just a smidge bit of gas at an idle, the car bogs down and feels almost like the engine is misfiring until my rpms get fairly high (about 3000 or so). if the rpms drop too low, it bogs down and shakes really bad, and i wanted to know if you guys could help me. in neutral, if i tap the gas real quick, it does the same thing, and when i put it into first, if i give i push the gas pedal in too quickly, it bogs down just like in neutral. it only seems to be when i push the gas pedal down fairly fast. i have new plugs and wires, just cleaned out my K&N filter and just recently had a tuneup too. i've heard that sometimes the oil for the filters will get on the MAF and make it run crappy, but that should throw a CEL i think, which i don't have. i've tried putting everything i can think on here, but let me know if you need anymore info.
Old Mar 12, 2005 | 06:24 PM
01roller's Avatar
ever changed the fuel filter?? did you recheck wires and plugs??did you check anything out before you posted ??
Old Mar 12, 2005 | 07:10 PM
Solohan50's Avatar
sorry about this post, i got it taken care of. i guess tibs are very picky about how you align the plug wires and it seems that they were sparking across or some crap, cuz i got the diagram off the service website and it's running as well as my car can run, which isn't saying much. so once again, sorry about the waste of a post yo.
Old Mar 12, 2005 | 07:33 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
We won't hold it against you for too long. Glad you got it figured out.
Old Mar 12, 2005 | 07:42 PM
Rd1tib's Avatar
Just aligning the plugs wires help? Which way is it suppose to be aligned? My car been bogging for such a long time i sorta gave up...
.Edited.....NeverMind... i just checked webtech. ....
Old Mar 12, 2005 | 07:44 PM
01roller's Avatar
look on webtech. they have to be put in order with the piston sequence which off my head is...4-1-3-2.. not sure
Old Mar 13, 2005 | 12:00 AM
Solohan50's Avatar
that wasn't my problem. it was actually you had to put the wires themselves in exactly the right little holders and had to point the wires away from the plugs in a certain direction, otherwise they supposedly spark across each other or something. i don't have the link, but look under the spark wire troubleshooting on webtech.
