header question
Old Feb 28, 2005 | 12:59 AM
carbontib's Avatar
Default header question
Hi does anyboduy know if I4 OBX headers will bolt up to (withought modification to stock exhaust) a I4 2.0 2001 tiburon without the test pipe/downpipe part? Thanks.
.....please dont flame....im a newb laugh.gif:
Old Feb 28, 2005 | 06:14 AM
JalemX's Avatar
you will need the test pipe to match it up or else it would not be long enough.... but it will bolt right up as long as you have the test pipe (which is usually included)
OR if you were looking to get a cat converter you could replace the test pipe with that. which would also work
BTW, welcome to the forums... do you drive a 03 or a 00 tib?
Old Feb 28, 2005 | 10:47 AM
It says 2003 in his profile.
Just so you know Carbontib, we specalize in RD Tibs, the 96-01 Tiburons. You are welcome to stick around, but our help will be limited most likely.
Old Feb 28, 2005 | 12:41 PM
daoust's Avatar
i buy the obx header on ebay and it fit prety well on the stock exhaust without any change exept you have to put another oxygene sensor on your line if you have 2.
