Wierd Idle Problem
Old Jul 7, 2006 | 12:03 PM
gthaman's Avatar
The other day I got into my car and turned the ac on. The revs dropped to like 500, and then up to 800. Usually it drops a for 1 sec, and much less then that. It happens every time i turn the ac on, but the regular idle without the ac on is also a bit less then usual. And it jumps a bit up and down when starting the car. Any ideas of what this could be?
Old Jul 7, 2006 | 12:08 PM
funkypc's Avatar
Well, the idle is supposed to change (ie. jump up) when you turn the A/C on.
and when you start the car, the idle takes a couple seconds to adjust itself, if that's what you are referring to. If the idle is just being eratic though, I would say that could be your MAF or TPS.
Old Jul 7, 2006 | 12:47 PM
Could also be the idle air bypass solenoid acting eratically. Most likely TPS, unless you messed with your MAF.
Old Jul 8, 2006 | 01:16 AM
gthaman's Avatar
I have a map... probably the tps. Ill check it out.
Fixed it! It was the connector that goes into the round bosch thing... owned.gif
Old Jul 25, 2006 | 03:07 PM
Braker's Avatar
sometimes when the car is in idle the engine stops working. i have also noticed the the A/F ratio does not work as before the problem and sometimes when while im on the road the car does something like a kick... any ideas ?
we have changed: fuel pump, crack sensor, should we change the lambda ?
Old Jul 25, 2006 | 03:27 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
QUOTE (gthaman @ Jul 8 2006, 02:16 AM)
Idle Speed Control Actuator
Old Aug 2, 2006 | 03:10 PM
tdonnell's Avatar
^^^ Yup.
Whenever you have an idle problem, start with the intake system, i.e. looking for leaks and loose clamps, etc. Then work your way to the head, like plugs and wires, etc.
Glad it was a simple fix.
