Oil Pan?
Old Jul 17, 2006 | 10:51 AM
lilo shark's Avatar
i'm not sure if this has been asked before but since i was thinking of turboing my car. my buddy with his 2nd gen gst came over and i was looking at it. and it looked like the oil pan from there would fit on to the beta. i'm not to sure but the design is the same as ours, like where the crease goes up for the down pipe. how i thought of it, it would save time of drilling and tapping lines for oil.
correct me if i'm wrong.
Old Jul 17, 2006 | 11:29 AM
supercow's Avatar
anything is possible, I've never heard of anyone doing that or even thinking it would work.
Old Jul 17, 2006 | 11:46 AM
rallyman's Avatar
It's unlikely that two different car manufacturers are going to come up with the exact same design and bolt hole locations for their oil pans even though they appear to be similar. The best way to find out is to try it and see if it fits just remember to examine them both as closely as possible to avoid wasting your time. Check the bolt locations, dipstick location, etc.
If you decide to try it let us know how it turns out.
Old Jul 17, 2006 | 01:33 PM
xxxmonoxidechild's Avatar
pretty much every cars oil pan will look like it will work, but ive never seen one cross over like that. but being that the beta is loosely based on the mitsu motor, it has a possibility. but as said, i doubt it will actually work.
why not just use an 01 + elantra, 03+ tibby beta one? its an upgrade, and you know it will work.
Old Jul 17, 2006 | 02:21 PM
Alex01tib's Avatar
Hes just prolly looking for a pre tapped oil pan, just get an aluminum GK one and tap it off the car, its not that hard, a shop would be able to do it if you cant handle lmao.gif
plus it would look pimp
Old Jul 17, 2006 | 03:53 PM
allready posted that
Old Jul 17, 2006 | 11:14 PM
lilo shark's Avatar
i was going to go to autoazone or adavanced and take a look at both oil pan gaskets and see if they matched up. i just want to take the lazy way out of tapping the oil lines.
Old Jul 18, 2006 | 05:12 AM
it only takes litterally like 5 minutes to tap a return line, if your gonna go turbo, its probably one of the easiest things your gonna be looking at.
Old Jul 18, 2006 | 06:56 AM
well even if the gasket matches up it might not have the same curves to it
Old Jul 20, 2006 | 06:58 AM
Call_to_arms84's Avatar
Can anyone confirm that the aluminium oil pan from the Beta2 will fit on a Beta1?
