Oil Pan?
Old Jul 20, 2006 | 07:29 AM
^^yes
Old Jul 20, 2006 | 07:47 AM
I belive it holds an extra quart of oil also.
Old Jul 20, 2006 | 09:10 AM
supercow's Avatar
^^that is something i did not know...
I might have to do that if the future. how much are those pans new?
Old Jul 20, 2006 | 09:12 AM
JonGTR's Avatar
QUOTE (REDZMAN @ Jul 20 2006, 08:47 AM)
And how exactly does it do that? I doubt it does.
If it's deeper, then you would need a deeper pickup or you're screwed.
It's not wider.
And they don't ask for 5.5 quarts of oil in the Beta II's.
Old Jul 20, 2006 | 09:34 AM
lilo shark's Avatar
why do the beta 2's need more oil?
Old Jul 20, 2006 | 11:27 AM
rallyman's Avatar
They don't need more oil. It was a mistake. They use exactly the same amount as the Beta 1.
Old Jul 20, 2006 | 12:47 PM
Alex01tib's Avatar
QUOTE (xxxmonoxidechild @ Jul 17 2006, 05:53 PM)
allready posted that
I know, i was reiterating it and adding a suggestion about tapping it and that it looks good...
Old Jul 20, 2006 | 06:08 PM
QUOTE (JonGTR @ Jul 20 2006, 09:12 AM)
It's not wider.
Random had posted that once before I belive. It may only be a half quart or such, but it holds more he said.
Someone said.
I don't remember.
Old Jul 24, 2006 | 11:54 PM
Viper966's Avatar
i dont think it does hold more... it can be deeper without the need for a longer pickup as long as its baffled
Old Jul 25, 2006 | 10:05 AM
supercow's Avatar
probably just a mistake. Every oil change I've ever done on the tib I've only had to put in 4 quarts and I always change the oil filter when I put in 4.5 it was always a little overfilled. After taking the pan off I found that some doesn't drain... about 1/2 quart. When I filled the oil up after putting the pan back on it needed 4.5 quarts.
