Megan Shifter Problems?
Vehicle: 2000 hyundai tiburon
hey guys, i bought a megan short sifter a lil while ago, maybe 5-6 months and last nite i was driving i stopped went to shift and it has gotten really hard to shift. it used to be smooth it now feels like something is blocking it from going into gear. i dont know if anyone else has been haveing this problem but can anyone help me figure this out. i just bought it and really dont have the money for another. please advise is needed. i already di a search and nothing like this has been mentioned so please help. money is scarce
just so you know i have already looked to see if anything was blocking it and the path is clear. so i dont know wtf is the problem
I had posted up a problem with it a while ago. You should check it ASAP.
The first pivot point, under the shift knob, that pivot likes to work loose. If it's loose, take it off, clean it really good, put a bit of grease on the smooth part of the shaft (insert phallic refrence), and some locktite on the threads. Tighten it down enough to where it still moves smoothly, and let the locktite dry.
