Just Finished Checking Compression..
Old Oct 6, 2006 | 03:32 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Fuel pump relay removed.
Coil pack disconnected
Fuel lines empty
Car warmed up
Gas pedal all the way down
#'s are after 3 cracks each cylinder.
My engine has 90k miles. Also I forget, but does compression tell you if you have a head gasket leak? I think I see oil around the bottom end. Haven't fully inspected yet.
Cyl 1 223
Cyl 2 224
Cyl 3 230
Cyl 4 231
Is this even possible with my milage LOL.
Each sparkplug had a greyish tip with a bit of brownish color around the end.
Post up your thoughts.
Old Oct 6, 2006 | 04:27 PM
holy badass compression badman.. better numbers than i had..seems a lil higher than stock, which is weird..
Old Oct 6, 2006 | 04:51 PM
xxxmonoxidechild's Avatar
wow, those are pretty high, ive actually never done the tibby, but im used to good #'s being around 145 in my probe. but thats has alot lower compression compared to the tibby.
Old Oct 6, 2006 | 06:51 PM
Tri-Pod Racing's Avatar
Good numbers would be 125 across all cylinders. Those numbers you posted seem extremely high. Just my opinion, I could be wrong.
This test will show you if you have leaking valves/stuck valves, blown head gasket, etc. Also, high compression could be caused by oil getting in to the cylinder, past the rings or leaking past the valve guide seals.
Old Oct 6, 2006 | 07:58 PM
tanc's Avatar
Stock compression is 213psi, its in Web Tech. So I'm not sure were your getting your "good" numbers from Tri-pod Racing.
I need someone with a bit of experiance in this field to let me know if this high compression is normal or ....?
And if my head gasket is good...from where is there oil on the bottom end near the head. LOL.
Old Oct 6, 2006 | 08:15 PM
12SecRD's Avatar
the guage maybe off some...its only a 10-15 psi difference
Old Oct 6, 2006 | 08:41 PM
tanc's Avatar
QUOTE (tanc @ Oct 6 2006, 09:58 PM)
Also I don't think the guage is off at all at max 1-3psi.
Old Oct 7, 2006 | 01:57 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
Very good numbers! Very close to each other and high.
Old Oct 7, 2006 | 04:38 AM
tanc's Avatar
What I am asking is, is it possible to achieve these #'s or are they too high?
Old Oct 7, 2006 | 08:26 AM
its possible mang....
as for the oil
clean if off with a rag and see where its coming from could be leftovers that you spilt while changing the oil or even a failed valve cover gasket
