Oil Burning
Old Nov 29, 2006 | 05:05 PM
tiburon354's Avatar
my car seems to be burning oil. i havent noticed any puddles after it been parked, so i dont think its leaking. but i have to put a quart every 500kms. what could the problem be? do i need a new engine? or is it cheaper to have the engine rebuilt? what about pcv valve? does anybody know?
Old Nov 29, 2006 | 05:37 PM
hamhead's Avatar
A quart every 500kms? Ouch.
Ya, its about dead.
Do a compression test or leakdown test, chances are your numbers are way out of spec and its time for a new motor.
Old Nov 29, 2006 | 05:51 PM
wolfinsheepsclothing's Avatar
check your valve cover gasket... just in case, because hyundais love valve cover gasket leaks. but it sounds like alot of oil lose.
Old Nov 30, 2006 | 04:24 AM
tiburon354's Avatar
i have a 1997 tib. now, would i be able to put, for example, like a 2003 motor. would it be the same size? or should i find a 1997 motor? how much would a used motor be? also, i have a 1.8. could I put a 2L without too much hassle, or would i have to change all the sensor and everything?
Old Nov 30, 2006 | 04:55 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Whoa whoa whoa,
Your getting a little over your head, don't you think?
Run a leak down test, read the results than decide.
Old Nov 30, 2006 | 04:57 AM
Osv4's Avatar
Well the 2003 model is a V6 so it is bigger and it doesnt have that much more power..this question was discussed a lot and it is just worthless swap laugh.gif
You can put a 2.0L Beta engine from an RD1 or RD2 with no problems wink1.gif
As for the oil getting burned, my car does that aswel..Some mechanics suggested getting my engine head serviced and replacing the valves in the engine. They said its about 90% chance that it would stop the burning of oil..I dont think it actually gets burned, i think it just goes out into the air through your exhaust wink1.gif
After getting your engine rebuild your engine is basicly brand new as most if not all internal parts would be replaced, if you can get a new engine for cheap price you may aswel do that, cos the rebuild will cost more as there is more labour involved wink1.gif
Old Nov 30, 2006 | 07:30 AM
rallyman's Avatar
The oil certainly can be burned in the engine. If your car is burning oil you will see blue smoke coming from the tailpipe. You are experiencing severe oil loss/consumption so it would be best to have it repaired. Oil could be getting past worn piston rings or valve seals and be burned in the combustion chambers.
Is this condition something that just started happening or has it been getting progressively worse? Perform the tests others mentioned above to point you in the right direction.
I have seen used engines selling for about $400 and up in Ontario and some of them are low mileage so that might be an option for you as well. You could use the engine from any 97-01 Tiburon or 96-00 Elantra.
Old Nov 30, 2006 | 01:38 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
Even with good compression engine can burn oil. Like mine did.
Oil rings were bad, but compression rings held compression.
Check if you have a lot of oil in the pipe that goes from filter to throttle body. Usually oil rings are bad - you will find there lot's of oil.
