Need Help Diagnosing Problem.....
Old Oct 8, 2006 | 05:08 PM
cbehage's Avatar
I replaced my dead engine with one from a yard.
The car does not want to idle. When I give it gas, the rps drop. If I hold the pedal down, rpms slowly climb.
Once the rpms are above 2500 I can hold them and it revs smoothly.
Since then I have changed the TPS, TPS wiring, MAF, Idle control, plugs, plug wires, Fuel pump, battery, battery terminals, alternator, ecu.
Seems like a tps problem. What should I look to replace next?
Injectors
Crank/cam sensors
Throttle body
Please help
Old Oct 8, 2006 | 05:30 PM
wow you replaced a lot of stuff. any cel? if so get it scanned
Old Oct 8, 2006 | 06:19 PM
zoned019's Avatar
Vehicle: 97 Tib
sounds to me like you have a vacuum leak..
OR, lol, i'm serious about this but...is your MAF pointing the right direction?
Old Oct 8, 2006 | 06:46 PM
hamhead's Avatar
I'd take a careful look at the hoses for the Idle Air Bypass and other vacuum hoses in that area, and inspect them for leaks/clogs.
